Vantage just closes as it loads vrscene
  • Vantage just closes as it loads vrscene
    Hello,
    I am trying to open a .vrscene but no luck. The scene itself is heavy, 8GB uncompressed on my HDD. 3ds Max stats show 133 mil polygons, plenty of forest pack objects inside.
    Things I tried:
    1st export was compressed vrscene, all settings to default. Didn't work
    2nd: uncompressed vrscene, all other settings default. Didn't work
    3rd: uninstall vantage 2, restart pc, install vantage 2, open scene. Didn't work
    Every time it happens as vantage loads the instances, at about 50%. I attach the debug log in case it helps.
    System setup: i9-9900K - 64GB Ram - RTX 3090 - max 2024 - Vray 6
    update:
    exported everything besides forest pack objects. Worked.
    No textures are loading for some reason.
      Can anyone explain to me why the situation in the attached image happens?
      As you can see, the box on the left came with the exact same material applied in 3dsmax. The box on the right with the same material applied from cosmos within vantage.
      I tried "archive" in the vrscene export dialogue.
        Hi iouzounis,
        From the first post, where you send the log, I cannot see anything peculiar apart from it just suddenly stops. From the second post, where all objects are grey, I can only guess that it could be exported with an override grey material? Can you please send the scene for us to investigate? You can use the chaos help center and when the support team receives it we will write back our findings.
        Alexander
        Alexander Atanasov
        V-Ray for Unreal & Chaos Vantage QA
        Chaos
          Alexander, you are the man! I was getting ready to bang my head on the wall over such a tiny but crucial detail Indeed I forgot the override material...
          I will investigate the forest objects one by one and will keep you posted on what I find.
            OK, I tried all forest objects one by one. All worked as expected. Exported all geometry in one file and all forest objects in another. Opened one file in vantage and imported the other. They are working nicely. I don't know what was happening before but with this way it works.
