No rendering in live link
  • No rendering in live link
    Hi, I was wondering if someone can help me with this problem.
    When I want to render via live link from 3ds max, vantage renders only one frame and then waits for the next frame that never arrives, it only renders one frame, I have tried with projects with animations, with empty projects, and it is always the same problem.
    Yes, the same here.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Are there errors in the MAXScript listener (F11)?
      Nikola Goranov
      Chaos Developer
        I Have the same problem, when i try to live link render a sequence animation is freezes after frame 1, seems impossible to render an animation with live link in vantage 2.0......
          Hi VR-studio,
          Can you please downgrade to 1.8.6 and see if the problem persists with the same scene or is it only reproducible with the 2.0 version?
          Alexander
          Alexander Atanasov
          V-Ray for Unreal & Chaos Vantage QA
          Chaos
            Hello, My render animation via Live Link causes the image to never finalize rendering. The render progress bar continues but the rendered image turns black a split second and proceeds to render from the initial render iteration. It seems like it is disconnecting from live link every 5 seconds. The final saved image is splotchy like it only rendered for a few seconds, but the frame really rendered for 20 minutes.
            -It rendered fine the night before...I don't think any settings changed.
            -It is scene specific, but merging the objects into a fresh scene does not make a difference.
            -I exported as vrscene and stopped live link. It renders fine with no issues.. I need to render via live link I have 3dsmax animated camera.
            **I have uninstalled/reinstalled vantage 2.0. I have updated to the latest Nvidia drivers.
            Any other suggestions.
            Jerome
              You don't need the live link to render an animated 3dsMax camera.
              It should work through .vrscene too.
              Greetings,
              Vladimir Nedev
                Greetings,
                Vladimir Nedev
                I did not know that you can export animated camera with the vrscene. Thanks, so I will skip live link..
