I tried using Vantage for rendering Element Channel, and now it has correctly preserved Vantage's color correction in the RBG file. However, the rendered pngs cannot be read as sequences, as they appear to be separate files for each frame. Chaos player cannot read them as sequence files. Their sorting is also very strange. The sorting is different from that rendered by VRay.
Normally, they should be
01_ 00000. Atmosphere
01_ 00001. Atmosphere
01_ 00002. Atmosphere
01_ 00000. Lighting
01_ 00001. Lighting
01_ 00002. Lighting
Arrange each type in this way, rather than sorting each frame separately
Vantage:
When I place the frame number at the end, the sorting is normal and it can also be recognized as a sequence normally
Perhaps it should be modified in this way
Naming.Rendering Element Type.Frame
VRay:
01_ 00000. Lighting
01_ 00001. Lighting
01_ 00002. Lighting
Vantage:
VRay:
