scene states messing things
  • scene states messing things
    Dear Vantage team
    scene states now is very confusing and causes problems.
    For instance on one new scene I load two vrscenes (in this case two animated trees) and I place them accordingly, during the process I save vantage scene so it automatically saves scene substates of objects.
    Then when I create the cameras and I set them for animation , the objects vrscenes move back the trees to their initial position. the same for when i render animation .
    I think it all comes because there is no way to render with scene state none.
    Can you please fix this
    Can you send us the vrscenes with the animated trees, so we can reproduce the issue here ?
    I am not sure it's the scene states that are causing this issue. Was this a problem in Vantage 1.8.6 ?
    If the transform of the trees is animated in their vrscene file, when you play the animation, this will override any changes you made to the transform in Vantage.
    I think you already requested a solution to this in another thread.
    Greetings,
    Vladimir Nedev
