How to set output by vantage_console(vantage 2.0)
  • How to set output by vantage_console(vantage 2.0)
    Hey guys,
    There were output and frames options in the previous version, but they are gone now. How can I set the output through command line in vantage 2.0?
    I found HTTP api is work.
    Code:
    import requests
    import json
    source_attr = {
    'command': 'startLiveLinkSequence',
    'path': 'c:\\1.png',
    'width': '1024',
    'height': '1024',
    'samples': '100',
    'startFrame': '1',
    'endFrame': '1',
    'fps': '30',
    'lightCache': 'true',
    'denoiser': 'true',
    'pngAlpha': 'true',
    'denoiserForIntermediate': '1',
    'temporal': '1',
    'motionBlur': '1',
    'autoExposure': '1',
    req_json = json.dumps(source_attr)
    a = requests.post(r'http://localhost:20702/command', data=req_json)
    print(a.json())
    didaxr
      Thank you @didaxr ,
      I am not familiar with the API. Can you (or any other digital-samaritan) explain how to use that script?
      Thank you very much
