Warning : Could not connect to host 127.0.0.1:20701:
  • Warning : Could not connect to host 127.0.0.1:20701:
    Hi ... I keep having these log errors... when i start live link with vantage 2.0....
    do you know how to solve it, or what can cause the problem?
    thank you
    my GPU device and setting
      Do you have Vantage running when you do this ? Or maybe a firewall is blocking the connection ?
      Greetings,
      Vladimir Nedev
        Are you sure you have a license?
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090 X2
        • ​Windows 11 Pro
          Yes I do and works
            Yes I do and is running, all the software connected with the license work perfectly... vray an d phoenix fd... no problems
              Greetings,
              Vladimir Nedev
              yes I did also tried the firewall
                Does it get fixed if you restart both 3dsMax and Vantage ?
                Greetings,
                Vladimir Nedev
                  Greetings,
                  Vladimir Nedev
                  I have tried but unfortunately not.... I have tried also to reinstall Vantage but nothing seems to work it works only if i export the scene as vrayscene
                    Yes, but Vantage was removed from Premium. I say becasue I had the same error and it was becasue Vantage 2 came out, and was removed from Premium, requiring its own seperate license.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Before attempting Live Link, start Vanatge from the start menu or desktop. Check if the Live Link menu looks like this screenshot: https://docs.chaos.com/display/LAV/Live+Link+Menu
                      If it does and you still get the same error, I think it's 99.9% caused by security software blocking the connection.
                      Nikola Goranov
                      Chaos Developer
                        DID they remove it from premium while i had already paid for......? that is unbelivable.. really? that is not correct.... to change when i paid in advance for the whole year subscription.... thanks for the info... then you might be right that is why is not working...wasting alot of time looking for a solution... not even an email where they advise the change
                          Yes, they removed it from the premium package and it is now its own things. The premium package also stayed the same price. They sent out some emails about the change.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            No, Vantage was NOT removed for users who HAD bought premium before 2.0 was released. It is available for the remaining duration of these subscriptions. It is not included in Premium only for purchases made after the 2.0 release.
                            Nikola Goranov
                            Chaos Developer
                            • #15
                              my resaller said that it works for the whole period of subscription made in advance ... that is why vrayscene is uploaded in Vantage and works ..... but i still can't get livelink working....
