Textures rendering on some frames, but not others.
  • Textures rendering on some frames, but not others.
    Hi All,
    I'm just trying to render out an animation sequence, and it's showing some quite strange behaviour where some textures randomly drop out. It's most noticeable on the road (which is an asphalt texture straight from chaos cosmos), but it also happens on other textures such as the grass, etc.
    Any thoughts on why?
    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
    www.robertslimbrick.com
    Cache nothing. Brute force everything.
    Are you using live link to render the animation ?
    Can you send us the scene and a clip showing the steps that lead to the issue ?
    We have to reproduce it in order to fix it.
    Greetings,
    Vladimir Nedev
      Apologies for the delay in getting back to you - been on annual leave.
      Yes, I have been using live link to render the animation. Is this not correct? (I am an amateur with Vantage).
      I'll send something across as soon as I get a chance.
        Yes, I have been using live link to render the animation. Is this not correct? (I am an amateur with Vantage).​
        No, it's ok to use it, we just need as much information as possible in order to reproduce the issue.
        Greetings,
        Vladimir Nedev
