the rendering doesn't start
  • the rendering doesn't start
    Hi guys,
    Does anyone know why the calculation for the animations doesn't start? This is happening to me with the latest build even in a single cube scene. While in still image mode it works​
    I just installed the previous build and it works while the last one does nothing, it doesn't start. Does it only happen to me?
      Hi visualtracing__
      Thank you for reporting it. It is a bug(LAV-1613) and we will be looking into it ASAP. From the screenshots I think you are in a Live Link session, have created 2 cameras in Vantage, animated them, and trying to render a sequence from the animation, correct? If it is so there is a workaround for it:
      1. Save a .vantage file so that the cameras are saved;
      2. Export a .vrscene and load it in Vantage;
      3. Load the vantage file saved in step 1 - the cameras and animation setup should load properly
      4. Render out the camera sequence
      Tell me if the workaround works for you.
      We will let you know when we have a proper fix for it.
      Alexander
      Alexander Atanasov
      V-Ray for Unreal & Chaos Vantage QA
      Chaos
        hi, exactly, I was rendering to live link.
        I'll try your procedure tonight.
        Thank you​
          Render as JPG and then merge video in other software. Render to mp4 doest work for some reason.
            I remember rendering at 100% didn't work. it had to be anything less than 100%.
            Bobby Parker
            www.bobby-parker.com
            e-mail: info@bobby-parker.com
            phone: 2188206812
            My current hardware setup:
            • Ryzen 9 5900x CPU
            • 128gb Vengeance RGB Pro RAM
            • NVIDIA GeForce RTX 4090 X2
            • ​Windows 11 Pro
              I just Cancel and start again, sometimes it takes two-three tries for it to kick in but it usually does, both mp4 and rendering to images.
                Was there any resolution to this, I'm having the same problem. Where can I download the previous version of vantage?
                  There is a "Show all versions" checkbox on the download page.
                  Nikola Goranov
                  Chaos Developer
