axis problem after import
  • axis problem after import
    Hi guys,
    I'm working on Cinema 4D and while waiting for the "render via link" function, I'm trying to export the scene and then subsequently add moving animations, such as a fireplace flame. I'm noticing though that there is a problem with the axis as soon as I simply add the Cloth tag. I attach screenshots before and after applying the tag.
    Thank you​
    Can you attach a sample scene ?
    This happens only with the cloth tag ?
    Does it render correctly if you use V-Ray to render it ?
    Greetings,
    Vladimir Nedev
      Greetings,
      Vladimir Nedev
      HI ,
      yes with vray it is rendered correctly. I attach the scene and this happens as soon as you assign a fabric tag.
      I tried to align in Vantage afterwards but as the animation starts the object returns to its initial position therefore impossible to use.
      Thank you​
        Hi visualtracing__,
        Unfortunately I am not able to reproduce the issue with your scene. Regardless if the plane has the Cloth tag - it stays in the same place. Which V-Ray version are you using and can you send an exported .vrscene with and without cloth tag to check on our end?
        Regarding "I tried to align in Vantage afterwards but as the animation starts the object returns to its initial position therefore impossible to use." this is a known issue(LAV-1246) but haven't gotten to it yet.
        Alexander
        Alexander Atanasov
        V-Ray for Unreal & Chaos Vantage QA
        Chaos
          Originally posted by Alexander.Atanasov View Post
          Hi visualtracing__,
          Alexander
          HI ,
          Thanks for looking into it. I tried even now but I still get the same problem.
          I attach the two vrscene files with and without tags.
          I'm using the latest version of Vantage (2.1) vray for c4d 6.10.01 and Cinema 4d 2024 on windows 10.
          Thank you​
            Hi Alexander.Atanasov,
            by any chance have you had the opportunity to analyze my files?
            I hope that the "live link rendering" function comes out soon at least there won't be these problems anymore.
            thanks​
              Hey, visualtracing,
              Would you be interested in trying the latest release of V-Ray for Cinema 4D? You can download it from https://download.chaos.com/?platform=70&product=47, and find more information about the release at https://forums.chaos.com/forum/v-ray...-now-available.
              Please let me know if you can reproduce the issue with the latest release. I recommend caching the cloth simulation before relinking or exporting the vrscene file.
              Cheers,​
              Boyan Nalchadjiiski | QA Engineer @ Chaos |
              E-mail: boyan.nalchadjiiski@chaos.com
                Originally posted by boyan View Post
                Hey, visualtracing,
                Cheers,​
                HI,
                I just tried but nothing, the problem is still the same even when saving the cache.​
                  Hey,
                  I have examined the scene file you provided, but unfortunately, I was unable to reproduce the issue. I suggest that you clear your Cinema 4D cache and, if necessary, zip it beforehand. 2/ Uninstall Vantage, and delete all settings as well, and preinstall it again. Let's try if possible.
                  Cheers, ​
                    Hey,
                    Cheers, ​
                    May I know the exact steps when you say to compress the cache? then when I uninstall Vantage I don't remember a warning to delete the settings too.
                    Anyway I'll try
                    It's good news that it works for you​
                      To be honest with you, it is not good news that we can not reproduce it locally. One more thing could please try with prior Vantage build 2.0 if possible.
                      Cheers,
                        Cheers,
                        I just tried version 2.0.1 of August 8th and the problem is the same. I also tried to export the file from Cinema 4d S26 but I get the same result.
                        At this point I would be curious to try one of your vrmesh files to see if it works. in this case it would mean that it is a problem with my Cinema 4d.​
                          HI,
                          I just wanted to tell you that I tried the latest build of Vantage 2.1.1 but the problem is still the same. he was hoping for the release of the rendering via link
                            Hi visualtracing__,
                            Do you Open or Import the scene in Vantage? Because I think that the issue may be happening when you import instead opening the scene.
                            Alexander
                            Alexander Atanasov
                            Chaos
                            • #15
                              You are right! I had never actually tried it.. thanks
                              However, it would be useful if it also worked when importing the object because in large scenes it is better to import separate animated effects and insert them later​
