Nothing
  • Nothing
    I have a scene that I am trying to push to vantage, and nothing happens. It shows exporting, stops after about 15 minutes, and nothing else happens. I have tried several times, waiting up to an hour each time.
Name:	Screenshot 2023-10-07 143303.png
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Does it have ForestPro objects with lots of instances ?
    You can try disabling those and see if that helps.
    Note that DXR has a limit of ~16 million instances, so if you are instancing grass on a large area,
    you should be careful and try to use larger patches of grass that's instanced less times.
    Greetings,
    Vladimir Nedev
      I went from detailed forest grass to to large, and that did the trick.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
