3ds max viewport background doesnt show on vantage
  • 3ds max viewport background doesnt show on vantage
    how can I activate background ımage on vantage
    Hi, thanks for posting. What host platform are you using? Are you using Live Link?
    If you are using a VRayLIght in Dome mode with an HDRI texture you will be able to see this in Vantage view port trough Live Link.
    If you have applied an image in 3ds max's environment slot or have set an image in 3ds max's view port these won't work trough Live Link in Vantage viewport.
    You can however set up a background image in Vantage itself. This is explained very well in the docs about Environment
    Click image for larger version  Name:	vantage_2023-10-10_16-02-00.gif Views:	0 Size:	3.27 MB ID:	1192892
    Vladimir Krastev | chaos.com
      I will animate, there are 1270 images, these images change as you scroll the animation bar, as you can see in the images I added, how can I show this background in vantage? It's not a single image, I don't know the English language very well,
Name:	Ekran görüntüsü 2023-10-10 164340.png
        Hi, animated textures/video background is not support in Vantage for now. We have this feature request logged in our system under LAV-1443. I will add your thread to the list and raise the priority.
