vantage 2.1.1 bug?
  • vantage 2.1.1 bug?
    Hi there
    yesterday i've updated the vantage to 2.1.1 and now when I open a scene (done in 2.1.0) and if I change the scene state (any one) Vantage freezes.
    here is a video showing that
    am I doing something wrong?
    thanks in advance
    best regards
    nuno
    https://www.dropbox.com/t/NlDvkORftsu1sUAT
    Hi, thanks for posting. Are you having these issues with every scene, even a new simple scene? Could you send us one of your scenes that has this issue so we can test it? You can do that here or trough the support contact form. If choose the contact form please include a link to this thread in your message.
    Vladimir Krastev | chaos.com
      thanks Vladimir
      right now, i've tested only with this scene. I'll try with others and send you a scene via support
      thanks for your prompt answer. really need this to work to deliver the project
      thanks
      best
      nuno
        (assuming this worked in 2.1.0) If you don't have time, you could download the previous build from our download page - just check the "old versions" checkbox.
        Nikola Goranov
        Chaos Developer
          Hi Nikola
          thanks for the prompt answer. yes it was working on 2.1.0
          what I've made, and since then is working normally in 2.1.1., was create a empty scene import all the vrscenes again with all the states clear and start all over and till now is working.
          in any case I'll send to support the scene in order to chaos team analyse
          thanks
          best
          nuno
