Animating DOF and FOV keeps changing during animation
  • Animating DOF and FOV keeps changing during animation
    Hello,
    I can't seem to animate the depth of field between two cameras without the FOV ramping up and down. This completely ruins the animated shot where there should be no other movement. Is there a setting I should be checking or am I doing something wrong? It doesn't matter what type of transition I seem to use.
    Thanks
    Hi rita_sobral,
    This is known and it has been mentioned in other treads (https://forums.chaosgroup.com/forum/...ported-cameras, https://forums.chaos.com/forum/chaos...n-and-zoom-out). We have it logged in our system under LAV-455. We will let you know when there is some improvement on the matter.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
