Fire (phoenix) on Vantage
  • Fire (phoenix) on Vantage
    HI,
    I imported flames made in Phoenix on 3ds max and imported into Cinema 4d via Volume grid object. In cinema 4d everything works as it should but it is not seen in Vantage.
    Is there any way?
    Thank you​
    You already posted this question here, there's no need to do that: https://forums.chaos.com/forum/chaos...re-volume-grid
    Your question is better suited for the Cinema section of the forum. You're looking for an equivalent of Max's Editable Poly conversion in Cinema, as you wrote yourself.
    Nikola Goranov
    Chaos Developer
      yes, sorry, I already posted it but not in the Vantage forum section.
