Bump Map
  • Bump Map
    I have a bump map on some water, and it looks excellent with CPU and GPU, but it doesn't exist in Vantage. What would cause this?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    You will need to add more details to the post, a screenshot for the material node tree will help.
    But as a quick guess, are you using stochastic tiling feature?, As that's not supported yet.
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
Name:	Screenshot 2024-01-08 195611.png
ID:	1199265 Click image for larger version
Name:	Screenshot 2024-01-08 195622.png
ID:	1199266 Thank you for the fast response. It is a simple water material with a noise in the bump map slot. Is the noise map the issue?
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Yes, unfortunately noise in bump map isn't supported.
        Refer to the official documentation for the full list of supported and not supported features :
        https://docs.chaos.com/display/LAV/3ds+Max#
        As a work around I would bake /render the map and use it with vray bitmap, you might need to cheat a bit to hide the tiling.
          Okay, thank you. I subdivided the geometry and added a noise modifier. It's just as good .
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Now I have noticed the added screenshot I think That's would do it too especially for such a small scene where the extra poly count won't be an issue. I'm glad you sorted it out! ​​​
              Plus, the benefit of geometry noise is that you can animate it and judge the speed of undulation better than with a procedural, when it comes to doing a nice
              Vantage sequence of that interior, which could look good I think
