Hello,
Something I've noticed is that when using 3Ds Max, TyFlow and Vantage, the simulation from TyFlow appears to lag behind by a frame. But it's not consistent, and it can sometimes be only part of flow within TyFlow, just like my attachments.
If you look at my flow, Event 006, you'll see that there's a time node, and once the particle goes to the next event, the shape and material ID should change together, but as you can see from the screen shot, the render in Vantage is a frame behind in terms of the geometry.
When I use Ty Cache, it's still happening too.
Anyway, just wanted to raise this in case there's a fix?
Cheers,
Dean
Cheers,
Dean
