Can't import camera from .vantage to 3DsMax
  • Can't import camera from .vantage to 3DsMax
    This issue happens a lot, starting with maybe Vantage 2.0.
    Nothing is imported into max.
    I am using Vantage 2.2.3 and 3ds max 2024.2
    Hi hill_lam,
    I tested with your vantage file and it imported 2 cameras:https://drive.google.com/uc?id=1l-Yy...LgxVWR5QJj_ZsH
    Can you record a video of the what is happening on your end?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Originally posted by Alexander.Atanasov View Post
      Hi hill_lam,
      Alexander
      Hi Alexander, I just found out what caused this problem. It may be related to the Windows system language.
      I use the Chinese version of Windows and the English version of 3DsMAX. There is a 30% chance that no cameras are imported and at the same time this error message will appear. No matter how I restart my PC.
      Suddenly I had an idea. I opened the .vantage file with Notepad and saved it as ANSI encoding. It worked! Finally the camera was imported successfully!
      I don't know why this happen. This usually happens when working on the same project for more than a few days. Don’t know at which point, the saved .vantage encoding suddenly changed.
      It's not a big deal once know the solution. Just a tip for friends who use Chinese, Japanese, and Korean Windows.
