Shadow Spots 2.2.3
  • Shadow Spots 2.2.3
    These spots are showing up in rendered output.... They appear when scrubbing the timeline briefly then fade away.
    Only happens when Nvidia Optix Ai is selected as denoiser (with or without final pass enabled). Does not appear when Intel Open Image Denoise is used... If you need the scene let me know before I wrangle that together.
      Hi, thanks for posting. The Nvidia Optix AI denoiser has issues in some scenes. Could you try to enable the "legacy mode" checker to see if this helps?
      If this does not work please send us the scene to the support contact form. Please add a link in your message to this thread for better tracking.
      Vladimir Krastev | chaos.com
        Awesome! Thanks for pointing me there! That solved it.
        Here's what was rendering:
        Legacy Mode:
          I had never used the DLSS ray reconstruction before.... That's pretty freaking rad. Is there a way to render sequences with that?
            Hi, the DLSS is used when moving around the scene.
            For high quality render sequence the NVIDIA OptiX AI or the Intel Open Image Denoise are used.
            https://docs.chaos.com/display/LAV/Render+Setup
            This is a nice video showing the denoisers when moving trough a relatively heavy scene.
