Hello,
Thanks for the recent displacement update it is working well. I have come across an issue when using VrayTriplanarTex map and its setting 'Use displaced Surface'. When I toggle this setting it has no effect.
I want to turn this setting off so it uses the base geometry for the mapping otherwise I get really patchy texture and the continuity breaks with the more detail/displacement that I add
Can this be solved with Vantage?
Thanks
Thanks
