Hdri
  • Hdri
    Hello, I'm going crazy with Vantage. I'm using live link. I added an HDRI from cosmos and now when I want to use a hdri map from my local library it always return to the cosmos one. I've deleted it from the cosmos library and it always return to it. I cannot anymore use the one i've add to a dome lihgt or in the environment. I add merge everything in a new scene restart Vantage and it still try to une the hdri from cosmos even if it no more exist!!
    Vantage it's so cool to use but sometime i'm getting very frustrated to use it.
    Can you record a clip of this happening ? It might be a bit difficult to reproduce it otherwise.
    Greetings,
    Vladimir Nedev
      Did you add it in MAX? Sounds like you have 2 dome lights. If so delete the one created with the cosmos hdri. Otherwise, try to add the original hdr you want to use and save a substate and update your views in Vantage.
