When using VrayDecal, the GI is generated from the underlying object, not the VrayDecal material
  • When using VrayDecal, the GI is generated from the underlying object, not the VrayDecal material
    Hello,
    Just noticed something.
    Say I have a really saturated purple base object, such as a floor, I then apply a vraydecal on top, which is say grey, then any objects that sits on the floor will have a purple GI bounce, rather than a grey bounce. The GI isn't taking into consideration the grey vraydecal.
    The vray decal is visible and correct in the reflections.
    Dean Punchard > Head of CGI at HUB
    Hi suzanne_doherty,
    There is a Decal for glossy/GI option in the Advanced Render settings, it is off by default for performance reasons, that you can enable and this should sort the GI bounces:https://drive.google.com/file/d/1jk7...usp=drive_link
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
