Hello,
I work mostly on Sketchup + Vray + Vantage (latest versions) and my process is as follows: I export a vrscene from SketchUp and open it in Vantage and it works great, superb results. Once my Vantage file is open and set for rendering, I want to import another vrscene into my current scene as I want to add details that are animated or don't look good on SketchUp. I can import, see and move my imported vrscene by using the tools inside Vantage (usually people or furniture). So far so good but when changing cameras and closing and reopening the file, my imported vrscene goes back to its origin ( 0,0,0 point where the X, Y, and Z axes intersect) aligning as well with the original Sketchup file origin. I successfully rendered an animation with new camera (set after the vrscene was repositioned) and it worked. However once I close and reopen the file, the vrscene scene goes back to its origin. I have tried to drag and drop the vrscene and used the Place option to a specific location but the issue is still the same and the imported vrscene always goes back to its orign. The imported vrscenes are from 3Ds Max but I don't own the software and therefore doing anything from there wouldn't be good for me.
Is there anyway I can seal the position of my imported vrscene?
Thank you in advance.
