chaos scatter lagging
  • chaos scatter lagging
    when you have a large root vrscene in vantage of 15 GB VRam for instance.
    you can navigate very smooth, and you can move objects in the scene very smooth,
    If you create a scatter of even one instance of a very light object like a cosmos people or whatever, and then you move the plane on which you created the scatter then this object is lagging
    Can you demonstrate this with a video clip, I am not sure I understand completely.
    Note that scatter instance generation is done on the cpu.
    If one scatter update is slow, subsequent updates won't happen until you depress the mouse button (whether moving an object or moving a slider).
    This doesn't depend on the complexity of the underlying scene, just the complexity of the scatter object.
    Is this what happens in your example ?
    Greetings,
    Vladimir Nedev
