bug
  • bug
    Salut
    Chaos Vantage plante constamment depuis la dernière version et c’est le message que je reçois
    que puis-je faire ?
    MERCI
    Hello, please write in English so that everyone on the forum can read your messages.
    It seems you are using Vantage 2.4.0, but there is already version 2.5.0 available.
    Can you share the log file from: %APPDATA%/Chaos Group/Vantage/debug_log.txt ?
    What were you doing when this happened? Were you using a large scene or did it happen as soon as you start Vantage?
    Nikola Goranov
    Chaos Developer
      First,sorry for the french language chrome was in automatic traduction
      I have installed the last version of vantage now and i will see if the problem continue.
      I join the debug_log.txt.
      When the problem arrived, I am rendering a large scene, juste one picture not a sequence in UHD 4K. The meesage arrived during the render maybe about 40%​
        Thanks. The log file is overwritten every time you start Vantage. The file you shared contains no errors and it looks like you just opened and closed Vantage. You need to copy the file after the application crashes.
        Are you using Live Link?
        From what you describe and from the screenshot above, it looks like you may have run out of GPU memory. Maybe closing all other applications will free up some GPU memory.
        Nikola Goranov
        Chaos Developer
