Vantage 2.5 Chaos Scatter not working
  • Vantage 2.5 Chaos Scatter not working
    Trying to Live link a scene made with Vantage 2.4 and the Chaos Scatter is not working at all.
    Am I missing something or is just a bug?
    Thanks!
    Does it work if you go back to Vantage 2.4.0 ?
    Which version of V-Ray for 3dsMax are you using ?
    Edit: I tried a simple Chaos Scatter scene with a live link from V-Ray 6 update 2.1 to Vantage 2.5.0 and it seems to be working.
    Greetings,
    Vladimir Nedev
      I just switched back to 2.4.0 and is not working anymore.
      I'm using 3dsMax 2024 and V-ray 6 update 2.1
        In that case, can you attach the scene here or send it to our support so we can figure out what's wrong ?
        Does it actually work in V-Ray itself ?
        Greetings,
        Vladimir Nedev
          V-ray GPU doesn't work with Chaos scatter either, only the CPU version does.
          Here is a test scene with the same issue.
          Thanks!
            What happens in Vantage and V-Ray GPU for you ?
            Does 3dsMax crash or the instances are just missing ?
            Greetings,
            Vladimir Nedev
              Max doesn't crash, the instances are missing in Vantage or V-ray GPU.
                Ok, thank you.
                For me, suddenly there are no instances with V-Ray 6 update 2, and 3dsMax crashes with V-Ray 6 update 2.1.
                We will investigate what the issue is.
                Greetings,
                Vladimir Nedev
                  OK, Thank you!
                    Did you recently install Corona v12 ?
                    If yes, you can try the following:
                    - manually uninstall Chaos Scatter for 3dsMax xxxx from add/remove programs
                    - install V-Ray 6 update 2.1 again (this will install an older version of Chaos Scatter)
                    The Chaos Scatter team is looking into a permanent fix for this that will come as a Corona hotfix eventually.
                    Greetings,
                    Vladimir Nedev
                      Originally posted by vladimir.nedev View Post
                      ...The Chaos Scatter team is looking into a permanent fix for this that will come as a Corona hotfix eventually.
                      Greetings,
                      Vladimir Nedev
                      Not very encouraging
                      Too bad when an update is released something gets broken...
                        Yes, I just installed Corona v12. I'll try this fix.
                        Thank you!
                          Greetings,
                          Vladimir Nedev
                          This fix worked, I also went back to Corona 11 because I was getting an error upon opening Max.
                          Thanks!
                            Is this problem solved with Corona 12 ?
                            Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
                            Sketchup PRO 25.0.634 + V-Ray 7.00.03
                            3DS Max 2025.3 + V-Ray 7.00.08
                            3DS Max 2026 + V-Ray 7.00.08
                            Chaos Vantage 2.8
                            GeForce Studio Ready Driver Version 572.16​
                            • #15
                              I have not updated to Corona 12 yet so I can't tell if it's fixed.
