Loading the same file in 2.4 works fine. Someone else experiencing this issue? Thanks
Vantage 2.5 crashing when "loading textures" from vrscene
Originally posted by carlmichaelk View PostThank you for your reply Vladimir. I found the issue being a 2 gig + texture flooding the memory in a shader. Back on track, but could be useful information, as 2.4 showed no issues with it . BR
Also what do you mean by "2 gig + texture flooding the memory in a shader" ?
Greetings,
Vladimir Nedev
Originally posted by vladimir.nedev View Post
Please send the scene to support, so we can fix the issue.
Greetings,
Vladimir Nedev
Can you at least give me more info about the texture
- resolution
- format
- number of bits per channel
- size on disk
- is it used as a normal map or something else
Greetings,
Vladimir Nedev
Originally posted by vladimir.nedev View PostCan you at least give me more info about the texture
- resolution
- format
- size on disk
Greetings,
Vladimir Nedev
- 16384 x 16384
- EXR
- 32 bit
- 2060 Mb
- Used as a normal map
BR//
- 16384 x 16384
- EXR
- 32 bit
- 2060 Mb
BR//
Greetings,
Vladimir Nedev
