Vantage 2.5 using more resources than before?
  • Vantage 2.5 using more resources than before?
    I just finished a project that was working seamless before I updated to 2.5. I made some additions to the model... Adding some interior information, but now I can't render a 4k image with that same settings I had before update. Now I can only render up to 3k before my vram gets exhausted and my laptop freezes. Working on a Dell with a rtx 4090 and 16gb of vram.
    Hi, thanks for posting.
    You have to compare identical scenes. Please the same scene in both versions of Vantage and let us know how it goes.
    Vladimir Krastev | chaos.com
      Just tested the same scene in 2.4 and it locks up similar to 2.5.1. So I guess I've hit my limit on the 4090 and have to render at lower res for now on.
        If you can send the scene to our support (with textures and .vantage file if any), it might be useful for us to understand and maybe optimize the memory usage.
        Greetings,
        Vladimir Nedev
          It's about a 1.2 gb file... how would I send it to you?
            Hi Luma3d,
            You can use the Chaos Help form(https://support.chaos.com/hc/en-us/requests/new) with a link to the forum thread. Once we have received and examine it we will get back to you.
            Alexander
            Alexander Atanasov
            V-Ray for Unreal & Chaos Vantage QA
            Chaos
              I can also confirm: 2.4 is much more smooth.
                Can you please record a comparison between the two versions that shows this difference ?
                We are not aware of such an issue, so we can't fix it.
                Greetings,
                Vladimir Nedev
