Can't set during time on Sun Animation
  • Can't set during time on Sun Animation
    I cant set during time on Sun Animation.
    The default is 10 seconds, I can use this function.
    But when changing during time it is automatically set to 0.33s and I cannot adjust it.
    The rest is very good.
    Thank you​
    So you right click on the sun animation track in the animation editor, set your custom duration but after you click OK it resets to 0.33s in the time line? Do you have other animations in the scene - from the scene track (vrscene file) or the camera track?
    Or do you mean that the duration of a rendered animation file is 0.33s? Sometimes the render dialog recalculates the animation length based on a previously used value and you may have to set the end frame in this dialog manually after changing the animation.
    Nikola Goranov
    Chaos Developer
      Hi, I experienced the same problem with this too. Please see my recording here : https://youtu.be/w8qPAbGd-ZI
      Im not sure why it only accept 10S, but after changing it, it cant be changed anymore
        Hi wendy_herdian,
        Unfortunately I cannot reproduce the issue from your video, I can set the sun animation duration without a problem. Can you share the scene so we can test it on our end? You can use the Chaos Help form with a link to the forum thread: https://support.chaos.com/hc/en-us/requests/new. Once we have something we will write back.
        Alexander
        Alexander Atanasov
        V-Ray for Unreal & Chaos Vantage QA
        Chaos
          This is weird, I kept having 403 error, when typing long sentences
            For the 403 forum error - try logging out and back in.
            Nikola Goranov
            Chaos Developer
              Hi wendy_herdian,
              That is strange indeed. Can you please video record the steps on your end so I can try and replicate them exactly as I am still unable to reproduce it.
              Alexander
              Alexander Atanasov
              Chaos
