Anima all - 4D Characters texture issue
  • Anima all - 4D Characters texture issue
    Has anyone had any issue with Anima all - 4D Characters? I export the animation as VrayScene, then when I bring the animation into vantage the textures brakes randomly during the animation, see pictures attached. any work around or solution. I am using the latest Vantage 2.5.and the latest Anima (July 2024) version.
    Hi richard_watson,
    Is the scene with the characters opened or imported? And if it is imported - what is the FPS that is set in Cinema4D? If the FPS in C4D and Vantage (30 by default) mismatch - this issue could occur. If that is not the case - then could you send us the scene and all related assets to the Chaos Help form with a link to the forum thread:https://support.chaos.com/hc/en-us/requests/new​ so we can investigate?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Thanks for the answer, Alexander, All three Scenes: Anima all / 3dsMax / Vantage, the frame rate, matches... All are setup to 25fps, but still I have that error, I have upload the different files to the link provided.
