Livelink problems
  • #16
    Hi npg Alexander.Atanasov , I've managed to get a work around that works fine now, livelink just doesn't work for me on these medium to large scenes.
    I managed to do my old method albeit ever so slightly differently, first I saved out the moving camera into it's own 3dsmax file and purged the scene, I then exported this using the 'export and send the current scene as static scene to Chaos Vantage', I then did the same process for my main scene (minus the camera), then, merged theses together and voila, working quick scene, I'm now able to render 3 frames per minute at 2k and also there are none of the manifold livelink problems.
    I'll try and send the scene at some point so you can see for yourselves the problem with Livelink, I've sent still images to your support showing some of the problems already.
    Thanks for your help so far,
    Jason
    AMD Threadripper 3990x 64C Processor, 128 GB DDR4-3200 Ram, 48 GB PNY Quadro RTX A6000, ​Windows Pro 10.0.19045.4894, 3dsmax 2025.3, Vray 62006, Vantage 2.5.2​
    • #17
      Any scene to reproduce the issue with will be greatly appreciated.
      Nikola Goranov
      Chaos Developer
      • #18
        npg, yep it's 15GB, that ok to send or will it bounce back?
        • #19
          If you send it on the ticket using our uploader there (I sent you a link to the uploader with instructions in the ticket) it should pass without any issues.
          Vladimir Krastev | chaos.com
