Hi there!
I know that Chaos Vantage is currently not compatible with Phoenix FD, so I followed this workaround: 3Ds Max - VANTAGE Tutorial | "How to render Phoenix FIRE simulations in Chaos VANTAGE" - YouTube, mentioned in Render Fire Animation using Vantage - Chaos Forums
The first simulation workaround worked just fine. However, I have two candle flames, and when trying to display the second flame simulation as mesh, nothing shows in Vantage.
Edit: If I copy (not instance) the first flame, it works. However, the second flame has the same setup as the first flame, which makes all the scene look fake. What parameters should I change in order to have a second, different flame?
Software:
- 3ds Max 2024 26.0.0.940
- Chaos Phoenix 5 ADV 5.20.00
- V-ray 6 update 2 (6.20.03)
- Chaos Vantage 2.6.1
Software:
