Problems with forest pack object
  • Problems with forest pack object
    Hi there. I'm rendering an animation with Vantage, with lot of Forest object in it (trees and bushes).
    Since yesterday everything worked fine. This morning I switched to Vary 7 and Vantage 2.6.1, and now Forest object don't render properly. They only shows envelopes of the geometry, and most of them disapper. See enclosed picture, the hedge in foregroung should be continuous. I'm using 3DS max 2024. Can someone help?
    You may need to wait for the Forest Pack updated build with support for V-Ray 7. Here is a link to one discussion:
    https://forum.itoosoft.com/forest-pr...a8129333922853
    Tashko Zashev | chaos.com
      Ok, thanks a lot.
        I know iToo released an update today for Vray 7, but I am still having issues where Vant is not rendering the materials when I even put Cosmos trees in the FP. Anyone else having this issue still? Max 2025.3 Vray 7, FP -9.1.4, Vant 2.6.1. Is this iToo issue or Vray?
          same problem on my side
          Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
          Sketchup PRO 25.0.634 + V-Ray 7.00.03
          3DS Max 2025.3 + V-Ray 7.00.08
          3DS Max 2026 + V-Ray 7.00.08
          Chaos Vantage 2.8
          GeForce Studio Ready Driver Version 572.16​
            Thanks for the update!
            We are looking into it right now. The support from the FP side (9.1.4) is now done for V-Ray 7 CPU, but it look like we have to make some improvements from our side now. Specifically for the export and GPU render.
            Issue #VMAX-14623
              To update, iToo just release 9.1.5 which now has solved the problem.
              https://forum.itoosoft.com/announcem...litepro-9-1-5/
                Thank you for the quick update PixelWindChill​, Tried the 9.1.5 here and confirm that it works.
