Vantage 2.6.1 Chaos Scatter not working
  • Vantage 2.6.1 Chaos Scatter not working
    did i miss something in new version?
    Tried a simple scatter scene - same. unless i convert scatter to max geometry
    Upd.
    tried even without link - still not working
    Hi vray_team,
    Chaos Scatter works as expected on my end. Which version of V-Ray and Scatter are you using? Can you show us an example of the setup?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Hi Alexander
      Thank you for response.
      Here is a screen capture. you can see vray, scatter and 3dsmax versions.
      and obviously, you can see result in vantage.
      (i tried to create scatter in vrscene in vantage directly - it works, but its unacceptable for me as i have several different scatters in 3ds max scene already set up, so really need to find a reason why it doesnt appear in my vantage)
      Click image for larger version  Name:	Screenshot 2024-11-05 104939.png Views:	0 Size:	986.4 KB ID:	1219620
      Thanks a lot!
        Hi Pavel,
        Can you please uninstall chaos scatter and then reinstall V-Ray, as I think this version of Scatter(6.0.4) is not compatible with V-Ray 6.2, it is compatible with V-Ray 7.? Please tell me if this solves the issue.
        Alexander
        Alexander Atanasov
        Chaos
          Thank you, Alexander.
          I will try to, but i dont think is incompatible.
          It was installed with existing V-ray and works perfectly.
          I dont think i will jump on V-Ray 7 as it's beta (or just a first rev.)
          Click image for larger version  Name:	Screenshot 2024-11-05 140651.png Views:	0 Size:	342.3 KB ID:	1219657
          UPD.
          After V-Ray 7 installation it wirks.
          It might be something wrong with my prev. scatter.
          Thank you for help!
