Chaos Scatter Axis is Off
  • Chaos Scatter Axis is Off
    Hi, does anyone know why the Scattered Object is Off? The Axis ist set on Zero in C4D and should be placed directly on the plane. Some Objects are even more off and completly under the plane. What could be the Issue? This only happens with Objects which I Export to Vantage from C4D. When I Import the same Models from Chaos Cosmos directly in Vantage, there is no Issue. This is kind of limiting in case of using different Assets except from cosmos.
    Hello ali_biyikli,
    Upon testing on my end, I didn't manage to reproduce this issue. Could you please let us know what are the exact versions of Vantage, Cinema4D, and V-Ray that you are using? Also, could you please share an example scene where the issue is reproducible? Thanks.
    Aleksandar Kasabov
    chaos.com
