When the rendering file is not render.xxx, the rendering time will increase several times
  • When the rendering file is not render.xxx, the rendering time will increase several times
    Is it a setting problem or a bug?
    This is weird indeed. I don't expect the name of the output to have such an impact. I have tried a couple of renders here using one of the sample scenes in Vantage, but can't reproduce this behavior. Do you have any screen-recording to show us what is happening? A scene file to try here? Or a screenshot of the Render Setup panel so we can use the same setup as yours. Anything that will be helpful to get this issue here will help for the troubleshoot.
    Tashko Zashev | chaos.com
      Yes, I agree with this, it doesn't happen often, sometimes it does. But I'm sorry, I didn't record the process, which is the case in some cases. So I'm also confused at the moment. It seems to be a bug, but it doesn't seem to be. Maybe I'll document it next time I reproduce the problem.
