what a disgrace is this
  • what a disgrace is this
    I wonder how much time you spend on this program that can't even run a simple material structure in vantage. we can't run the layout with a structure in the image below in vantage. why? something so simple on the cpu can run smoothly. it's ridiculous. we don't deserve this as people who pay for this software. if this program is a game engine, it should be advertised accordingly. i don't understand why architecture-oriented launches are made
    I leave the opacity map below, if anyone can run it in vantage, write
    Is this correct?
      Originally posted by hill_lam View Post
      Is this correct?
      I have tried everything. we are doing the same methods but the re ult is bad. did you change the color space of the bitmap
        No, I just dragged your bitmap into material editor and then linked it.
        Try change the Opacity mode in Vantage.
        Click image for larger version  Name:	20241121104139.jpg Views:	0 Size:	15.6 KB ID:	1220867
          ok thank you very much. so if I had not reverted to version 2.5.1 two days ago this problem would not have happened
            apologize to the whole chaos team now that the problem is solved
