Camera zooming out when pressing playback
  • Camera zooming out when pressing playback
    Hi guys, I think it may have already been mentioned.
    With latest version (2.6.1) I get weird zooming issues with some cameras when animating.
    Everything looks fine in viewport, but when I press playback button it zooms out - almost looks like an adjusted focal length...
    Had to revert back to previous version which works.
    Hi philip_nel,
    Yes, we are planning a release this week with a fix for it and other camera related issues. So sty tuned when it will be available and try it.
    Alexander
    Alexander Atanasov
    Chaos
      Any news on this I haven't updated Vanatge and have never had it occur before, but today it has started to play up. The camera zooms at the end of an animated sequence , but only whilst playing the playback, the scrub action with the play head is also very erratic so much that it is almost unuseable?
        Hi Martin, which version of Vantage are you using? We fixed some related issues in 2.6.2 and after that (for the next update), but I'm not sure if your issue is the same. Can you send a scene that reproduces the issue (as simple and small as possible, vrscene+vantage file) through our support channel? You can include a link to this thread.
        https://support.chaos.com/hc/en-us/requests/new
        Nikola Goranov
        Chaos Developer
          Hi Nikola,
          It was 2.6.1 but I have just installed 2.6.2 as part of the new license server instructions so I will try the same file and see if it still happens.
