2.6.2 can't render Spherical
  • 2.6.2 can't render Spherical
    2.6.2 can't render Spherical, always renders Perspective.
    You can test it in the blank scene at startup
    Yes, seems to be broken in 2.6.2, will make note to fix it for the next update. Thank you!
    Tashko Zashev | chaos.com
      Hi hill_Iam,
      Thank you for reporting this! Any Camera type are rendering as Perspective for Still images. However they work properly for animation sequence. A a sort of a workaround in the meantime you can add your camera in the Camera track in the Animation editor and render out a sequence of 1 frame. Hope this works for your case.
      Alexander
      Alexander Atanasov
      V-Ray for Unreal & Chaos Vantage QA
      Chaos
        I have the same issue. I have rolled back to version 2.6.1
