Struggling to setup the water surface in a model scaled in meters. Big landscape model with lakes. It seems I'm running out of decimals when adjusting the scale in the advanced settings. Will the object only work in default cm/inches scale? Or is there a trick to it?
Water surface scale
Hi tehamnes,
Thank you for reporting this! There is indeed an issue with the water surface object when the loaded scene is not in cm. I have logged it in our system under LAV-2095 and we will have a fix for it in the next release.
AlexanderAlexander Atanasov
V-Ray for Unreal & Chaos Vantage QA
Chaos
- Likes 1
