Vray Spot Lights - Texture not showing
  • Vray Spot Lights - Texture not showing
    Hello,
    I'm experimenting with projected textures using the Vray Spot light and the colour/texture slot in the editor to create faked caustic reflections in a pool.
    I am finding that i can only get Vantage to display a basic solid colour output and it will not show any mapped image in the texture slot.
    The spot light with texture map looks great in the Vray window but i cannot replicate this on Vantage. I am i missing a tickbox?
    The supported features per application on your website notes this as a supported feature. Am i missing something. Can anyone help with this?
    NB: For this particular use case I cannot use a rectangular light with 0.99 directionality as it then will not project onto the side walls of the pool. If anyone has an alternative approach please share!
    Are you using max? Try the standard spot light (not the Vray one)
      Hi Rita,
      Unfortunately not. Im, using V-Ray for SketchUp 2024 and live linking with Vantage 2.6.2
      But thanks
