Sky Banding
  • Sky Banding
    Hi all,
    Anyone know why I might be getting banding in the sky on this image from a movie below? It's being saved as standard .jpg so nothing special.
    I have avoided all OCIO colour management and the like as this is a quick project. Only thing of note is moving Vray Sun and moving clouds as well.
    Thanks,
    Jason
    AMD Threadripper 3990x 64C Processor, 128 GB DDR4-3200 Ram, 48 GB PNY Quadro RTX A6000, ​Windows Pro 10.0.19045.4894, 3dsmax 2025.3, Vray 62006, Vantage 2.5.2​
    Jpgs are usually 8 bit, so not enough color information. Maybe use a 16 bit png and see if that helps.
      Yep, as Luma3d suggested you can try with 32 bit output. With color gradients like in the sky where the values shifts in really small steps for big area, this banding can be very noticeable. One way to fix it is to not use Denoiser and leave some low level of noise in the image.
      Tashko Zashev | chaos.com
        Thanks for the responses guys, I've tried the EXR's and have the same problem, I'm not using Denoiser so that's ruled out. It's a strange one and I can only put it down to the moving sun and clouds.
          Banding happens when you have a low intensity gradient.
          This is usually fixed by dithering the image, something the V-Ray VFB has since some time, but we don't have it in Vantage.
          I guess it should be possible to apply dithering in a post processing or image manipulation program.
          Greetings,
          Vladimir Nedev
            I'm running into the same problem in low light situations... Doesn't the png file format save at 16bit or more?
