Corona live link...
  • Corona live link...
    Is really useless at this point in time in my opinion. I was running a simple test and it's definitely not wysywig. See attached images. And the rendering of animations is not a feature yet. Nor can I export keyframes of an animation in a vrscene.
    Yes, unfortunately the animation from Corona side is not implemented yet, but we are working on this.
    What are your concerns about the image in the FB and Vantage UI? The difference in the ground material ? If you have any adjustments set in the Corona FB they will not transfer to Vantage.
    Tashko Zashev | chaos.com
      Look at the lighting and shadows... not the same quality as the Corona fb. Should he wysywig... like it is when I use vray to Vantage.
        But you should not expect to get exactly the same render result from a totally different render engines (CPU / GPU/ new render engine). I'm not able to tell you without the scene files, if this results can be equalized more using CC adjustments or it is from something unsupported by the exporter or Vantage. But we can check this out if you send the scene to support help portal.
