Vray 7 camera correction
  • Vray 7 camera correction
    Is not translating over correctly in Vantage 2.6.2 when I initiate Live link. Using 3ds MAX 2025, Vray 7. I have the correction checked on MAX/Vray but it shows tilted in Vantage.
    This is a known issue (LAV-1836). It is not entirely on our end, there is some information missing from the Max exporter. As far as I know, the correction should work if you disable it before starting live link and enable it again after you are linked. Or maybe even if you just toggle settings while linked, I'm not sure.
    Nikola Goranov
    Chaos Developer
      You are correct... works after the fact.
