rhino crash with vantage / The process was terminated due to an unhandled exception / Attempted to read or write protected memory
  • rhino crash with vantage / The process was terminated due to an unhandled exception / Attempted to read or write protected memory
    Rhino crashes when working in Vray Vantage, this happens only when selecting a material in rhino with vantage open.
    Click image for larger version  Name:	Schermafbeelding 2024-12-19 105850.png Views:	0 Size:	368.2 KB ID:	1223420
    I'm getting this data from windows event manager:
    Application: Rhino.exe CoreCLR Version: 7.0.2024.26716 .NET Version: 7.0.20 Description: The process was terminated due to an unhandled exception. Exception Info: System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt. Stack: at UnsafeNativeMethods.Rdk_Globals_GenerateQuickConte ntPreview(IntPtr,
    Please give me some hint where I can fix the issue.
    Looking forward to hear from you.
    Thanks,
    Jacob
    Stack:
    at UnsafeNativeMethods.Rdk_Globals_GenerateQuickConte ntPreview(IntPtr, Int32, Int32, IntPtr, Boolean, Int32, UInt32 ByRef)
    at Rhino.Render.RenderContent.GenerateQuickContentPre view(Rhino.Render.RenderContent, Int32, Int32, Rhino.Render.PreviewSceneServer, Boolean, Int32, Rhino.Commands.Result ByRef)
    at RDK.Controls.NewContentControl.NewContentCtrlViewM odel.GenerateQuickContentPreview(Rhino.Render.Rend erContent, Boolean, Rhino.Render.PreviewAppearance, Rhino.Render.SceneServerDataUsage, Int32, Rhino.Commands.Result ByRef, Int32, Int32)
    at RDK.Controls.NewContentControl.NewContentCtrlViewM odel.CreatePreviewImagesAll(Boolean)
    at RDK.Controls.NewContentControl.NewContentCtrlViewM odel.DisplayData()
    at RDK.Controls.NewContentControl.NewContentCtrlViewM odel.OnDataChanged(System.Object, Rhino.UI.Controls.DataSource.EventInfoArgs)
    at UnsafeNativeMethods.IRhinoUiController_Commit(IntP tr, System.Guid)
    at RDK.Controls.GenericController.Commit(System.Guid)
    at RDK.Controls.NewContentControl.NewContentCtrlViewM odel.SelectContents(Rhino.Render.RenderContentColl ection)
    at RDK.Controls.NewContentControl.NewContentCtrl.Sele ctContents(Rhino.Render.RenderContentCollection)
    at RDK.Panels.ObjectMaterialPropertiesPage.ObjectMate rialSection.RefreshUICallback()
    at RDK.Panels.ObjectMaterialPropertiesPage.ObjectMate rialSection.RefreshUI()
    at RDK.Panels.ObjectMaterialPropertiesPage.ObjectMate rialSection.DisplayData(Rhino.RhinoDoc, Rhino.DocObjects.RhinoObject[])
    at RDK.Panels.ObjectMaterialPropertiesPage.ObjectMate rialPropertiesPage.UpdatePage(Rhino.UI.ObjectPrope rtiesPageEventArgs)
    at Rhino.UI.RhinoPageHooks.PropertiesPanelUpdatePageH ook(IntPtr, System.Guid)
    This seem to be a combination of an issue in Rhino and a wrong assumption of ours that there can be no issue in Rhino.
    Seems to occur only when the material panel had not be previously activated (not initialized). If you activate it at least once, prior the live link connection, there is no issue afterwards.
    Anyway, I fixed it already and the next update will include it.
    Thanks for reporting
      Hi Nikolay
      Unfortunately, that did not work in my case.
      When is the update coming? Because I can't use the program like this, it keeps crashing, also in different situations.
      Jacob
        It also happens when I got to viewport property's, rhino just stops working. For me, Vantage is not working at all. Please find a solution
          And with copy and paste from a second rhino file
            Vantage 2.7.0 still crashes when changing material in rhino
              jjoostwoud
              This was referring to the next V-Ray for Rhino update.
              Nikola Goranov
              Chaos Developer
                Ai, yes , sorry
                  I installed the new SR16 update and release candidate SR17 (13001, 02-1, but Rhino still crashes. Hopefully, this will be fixed soon.
                    I am not familiar with Rhino but this sounds like an update for Rhino itself. As I said, the issue was in the V-Ray for Rhino plugin. I think their next hotfix will be in a few weeks.
                    Nikola Goranov
                    Chaos Developer
                      Solved in the last update, thanks!
