warning disable rtxdi resampling not suported on multi-gpu setups vantage / !! But I have have one gpu installed !!
  • warning disable rtxdi resampling not suported on multi-gpu setups vantage / !! But I have have one gpu installed !!
    I'm getting this warning when rendering with Vantage for Rhino, then rhino crashes.
    Warning: Disabled RTXDI resampling because it's not supported on multi-GPU setups.
    Warning: Disabled light cache because it produces artifacts in multi-GPU setups.
    But I have only one GPU installed.
    Cant select one render device in Vantage, it keeps select automatically two cards.
    When rendering in Vantage, it takes all the memory and takes rhino down. See attachment for information.
    Can somebody explane what's could be wrong?
    Rhino keeps crashing for days in a row now. Please help
      The problem is solved after numerous attempt's en many adjustments, still I don't know what was the problem behind the behavior. But it works again!
        Hi and Happy new year!
        I have seen this behavior when there is a remote software running like Parsec, for example. It is autogenerating a new GPU instance device and this can cause issues with Chaos Vantage.
        Tashko Zashev | chaos.com
          Happy new year to you to!
          I have never used such a kind of software.
          Thanks for your reaction.
            Which version of Vantage were you using? The failure to restore your device choice was a bug that existed only in 2.5.2. It may also fail to restore your choice if the app crashed after you changed it, because this is saved when closing the app.
            We also improved the detection of duplicate devices in version 2.6.2.
            Nikola Goranov
            Chaos Developer
              I went from 2.6.2 to 2.5.2 and back, to solve yet another problem see post ( rhino crash with vantage / The process was terminated due to an unhandled exception / Attempted to read or write protected memory)
              ​. So it might be possible it took the bug from 2.6.2 back into 2.6.2. But this issue is solved, thank you.
