Hello, I have a few questions regarding two issues. I use Cinema 4D with Corona and I’m starting to use Vantage. The first problem I encounter is that the texture sizes set in the project in Cinema 4D do not match what I see in Vantage. Even when I try to scale the texture in Cinema through the live link, I don't see any changes applied in Vantage. The other question concerns animations. If I understood correctly, it's currently not possible to transfer animations from Cinema 4D/Corona to Vantage. For example, if I have animated trees in Cinema using the Forester plugin or liquids or fabrics, I can't export these animations to Vantage to take advantage of the engine's speed. So, is it true that those who can do this are using 3ds Max and V-Ray? Since Vantage is a paid software, it would be essential to have access to these features. When will this be possible? Thank you for the support.
Vantage texture issue and animation
Exporting the animation from C4D to Vantage is in our to-do list and now only the single frame mode is working. Maybe as a temporary solution, you can add Cosmos animated trees directly in Vantage.
Regarding the texture size matching issue, please upload to our ticketing https://support.chaos.com/hc/en-us/requests/new a sample C4d project file to see what is happening. Thank you!
