Emissive material with transparency (fire effect) not working
  • Emissive material with transparency (fire effect) not working
    Hi!
    I am rendering a fireplace, and when trying to create the fire effect, Vantage does not recognize the transparency of the V-Ray material. However, in the V-Ray render, the material works perfectly.
    Attached are the material settings in V-Ray and the preview from Vantage.
    How can I solve this issue? Is there any specific adjustment or configuration required in this case?
    Thanks!
    Do you have the opacity mode in Vantage set to "Clip" or "Stochastic" ?
    Greetings,
    Vladimir Nedev
      Hi Vladimir!
      We changed the configuration to Stochastic and it worked!
      Thank you.
