Array and Live Link don't always work
  • Array and Live Link don't always work
    So, when I'm using Live Link with Max, and then array an object, Vantage won't render every object (see attachments).
    Dean Punchard > Head of CGI at HUB
    Hi Dean,
    Does it happen in V-Ray IPR? Do you mind sharing this scene as I cannot reproduce it on my end.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Sending a file wouldn't work, as as soon as you re-open the file, the objects are visible.
      To replicate, it's not always the same. When using the array (Tools - Array) you might need to set the array to a lot of copies / instances, and add rotation as well as position.
      I will try IPR.
      Thanks,
      Dean
