Toggle opacity maps button missing
  • Toggle opacity maps button missing
    Using Vantage 2.7.0, worked well until this morning. Suddenly, the Opacity Map Toggle disappeared
    I tried going back to 2.6.2 and 2.6.1 but the problem remains.
    We don't have this button anymore because clip opacity is enabled by default.
    In the render settings, you can find the "Opacity" mode option where you can switch between "off", "clip" and "stochastic".
    The removed button switched between "off" and "clip", but then we added the "stochastic" mode in Vantage 2.6.0 and removed the button.
    Greetings,
    Vladimir Nedev
