Error during export & Can't select certain objects
  • Error during export & Can't select certain objects
    Click image for larger version  Name:	image.png Views:	0 Size:	963.3 KB ID:	1230261
    When opening the rhino exported scene,some errors occur (some unexpected objects pop out, out of nowhere)
    and I can't select them or delete them. (beside the unexpected error, there are other objects that I can't select ex.certain trees)
    anybody have some idea?
    If you can't select an object it probably means that it has the same name as another object. Vantage currently can't handle this. Try to give the objects unique names.
    Nikola Goranov
    Chaos Developer
